2.2Pro Class Breakdown
2.3 - Pro Class:
▪ 2.3.1 - Vehicle wheelbase is limited to a maximum of 12.5”/317.5mm.
▪ 2.3.2 - Vehicle track width is limited to a maximum of 12.5”/317.5mm.
▪ 2.3.3 - Wheel/ rim is limited to 2.2”/55.88mm or smaller at the bead surface. Wheels may be modified provided that the tire bead surface does not exceed 2.2”/55.88mm in diameter. With a tire mounted no exterior component of the wheel including but not limited to the bead lock ring shall exceed 2.55"/64.77mm.
▪ 2.3.4 - Tires may be modified from other sized tires using only a pliable rubber but must not exceed a total uncompressed outer diameter of 6”/152.4mm.
▪ 2.3.5 - Vehicles are limited to 2-wheel steering only.
▪ 2.3.6 - Vehicle body/ bodiless measurements must be greater than or equal to 8"/203.2mm overall length, 3"/76.2mm overall width, and 3"/76.2mm overall height.
▪ 2.3.7 - Limited to two motors.
